Thread: PB startup instructions? What's your thoughts?
    Apr 2016
    Houston, TX
    208
    What is your opinion on this startup, this what the PB left after he was done adding the startup chemicals.... Granted pool is looking crystal clear, maybe cause I been reading on here a lot and this just seems to easy to a certain point. PB left a Pentair test kit here for us, I have not been wanting to mess with it because I want to get used to my TFP-100 kit once it gets here and don't want to get confused..... Butttttttt I was curious today so I used the kind to do a FC test only, and it shows 0, And that is the reason why I'm in here right now asking lol...
    From what I been reading here suggestions are, stop adding chlorine tablets and added 1gal bleach everyday until TFP kit arrives?
    2016 pool build.... 18k gal. freeform style, built in round table, 18" jumping platform, travertine coping upgrade, travertine waterline, peagravel decking, saltwater pool (no spa), Quartzscape blue., 1.5hp Pentair pump, JANDY SWG, 48sqft Pentair DE filter, TFP-100 kit w/speedstir MYPoolBuild
    JoyfulNoise's Avatar
    May 2015
    13,231
    It all depends - do you have to do this to maintain your warranty?
    You need a good test kit right away as there is no advice anyone can give without test results. Without knowing your current CYA levels (if they added any) there's no way to know.
    Also, never add chemicals to your skimmer! That is just horribly bad advice. Trichlor pucks are acidic and a constant low pH load directly into your pool equipment each day when the pumps run will do more damage (especially to heaters) than anything else.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: PB startup instructions? What's your thoughts?
    Good job getting the TF-100, keep using it.
    I would follow this start up procedure from NPT.
    Overview | National Pool Tile Group
    It is fine to chlorinate with trichlor pucks and shock (dichlor?) at first. Just keep track of what you add, use Effects of adding chemicals in Poolmath to keep a tally of how much CYA you have added to the pool. And buy a puck floater to put the pucks in rather than the skimmer basket.
    The advice you are referencing is for someone who needs to SLAM their pool to kill algae, not start up a new pool. Please keep the context of the advice in the thread in mind when reading through different threads. And if in doubt post your own questions.
    Jun 2013
    South Florida
    118
    I would go ahead and add the tablets, but you need to be aware of how they raise the CYA level. I didn't read if the pool builder added initial CYA.
    Add the tablets to a floater though. Putting them in the skimmer is tough on the equipment.
    Basically, you need test results from the TF-100 and then you can make better decisions. But adding a couple tablets into a floater for a week is not going to harm anything.
    10,000 gallon in ground diamond brite, Circupool si30+, Hayward C900 cartridge, 1.5hp Flotec single speed pump
