Thread: Hello from Oklahoma dust bowl
    Jun 2016
    Beaver ok.
    1
    Hello I have had several different sizes of above ground pools. I had to retire my pool that lasted for four years and purchased a new pool that's one size smaller. Went from 18 to 16' which has to smaller intakes teed into one hose. I wasn't to sure about this setup when purchased and as suspected when I got it setup I hate it lol. So I google searched and I found this forum with its wealth of info and just had to join. I live in the OK panhandle with lots of wind and dirt so this pool really needs a good filtration system and found some good info here to modify my pool for better pump system. Anyway just wanted to say hello and Thank you for this forum.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Hello from Oklahoma dust bowl
    Welcome to TFP!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum!
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,236
    Welcome to TFP and good to have you here
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
