Thread: Jandy valve - two way - pool/spa - issue
    Jun 2016
    Harpers Ferry, WV
    2
    I've had the pool for about 10 years now. My valve was always set by my pool guys (who opens and closes my pool) to flow to the pool and to the spa. When in Pool mode, it would flow 98% to the pool and 2% to the spa. (well that's how the pool guys put it). The valve would be open ever so slightly tilt so it would flow to the pool and spa. It is a three way. I mistyped it in the subject line but can't change it.
    This year - they opened the pool and the pool guys (a new one this year) didn't do that. My spa quickly turned green (of course!). So he comes out today to investigate and he moved the valve by turning it off when the jandy valve was in an off position so it would flow to both place.
    Problem with that is now I can't turn on the SPA and Pool back and forth with my automation pad inside. I now have to put it back in C1 and then I can turn on the SPA. I never had to do that before in the 10 years and I told him that. He said that I need a bypass valve.
    So is there a way to adjust the valve and still use the automation (keeping it on?) If you need me to take pictures, I can. I appreciate any advice. I've been searching and can't find what I'm looking for.
    Thanks, Mike
    Last edited by SPIDEYMIKE; 06-10-2016 at 09:27 PM. Reason: not a two way but a three way
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Jandy valve - two way - pool/spa - issue
    Welcome to TFP Mike
    Your 3 way valve has a 24V controller on top of that valve, you can set how far it can move each way, here is a video..
    I hope this helps
    Jun 2016
    Harpers Ferry, WV
    2
    Thanks - my pool tech is recommending getting a SPA BYPASS valve. Do you recommend getting that instead of doing this?
