Results 1 to 7 of 7
Thread: Indoor pool out of control ????
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    This is my friend of the family indoor pool
    where to start first. Please
    I know iknow I can't get there with my TF-100 test kit yet
    Chris- Macomb, Michigan 20,000 gallon pool IGP. 16 x 32 Hayward Ecostar pump. Hayward 24 inch sand filter with Zeo sand. Hayward Aqua plus P4 automation board with T-15 turbo cell. Hayward H150 heater millivolts style. Polaris 9300 robot vacuum. New maytronics titain plus vacuum cleaner Test kits TF-100 and color Q7 TEST KIT.http://tftestkits.net.
    May 2015
    Mount Cheaha Alabama
    250
    Re: Indoor pool out of control ????
    Indoor pools require substantially lower CYA than outdoor pools. I think 10CYA is the recommended dosage for window light UV degradation
    FC levels that high are going to throw a false/high pH reading
    30k in ground vinyl lined pool surrounded by decking in the woods.
    Hayward sand filter circa mid 80's
    If there is a way to do things less expensively and yield a superior product I am all ears
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Indoor pools should have 20-30 CYA.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    The TA is also fine. I would only be worried if the TA were below 60 ppm... assuming the beep beep boop machine is correct.
    Isolated Spa - 345 Gallons
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    The chlorine generator is still on I will have them turn it off
    Should I drain some of the pool because the salt looks pretty high
    it's a Pentair Chlorine generator
    DFW, TX
    24,450
    If the SWG isn't giving a high salt warning then no need to try to lower salt. Pentair IC reports high salt warning at 4500 ppm, but will continue to produce chlorine even with high salt.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    First you should retest with a reliable test kit, second you should get the pH in line, third you should ignore the TA number and instead chase pH stability which will be a certain TA number, not the other way around.
    ps I maintain the CYA on my indoor pool between 20-30 ppm, this is because the CYA turbidity test minimum reading is 20 or 30 ppm depending on which view tube you use, also with indoor pools CYA is about buffering FC not so much about UV protection
