Thread: New pump - did I overdo it?
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    I recently picked up a Doheny house brand 1.5hp pump. The existing filter is a Hayward 210T and from what I can tell has a designed flow rate of 44 GPM. The pump is apparently 83 GPM (dumb I know, wasn't even thinking about it).
    There is some, but not a lot, of sand settling onto the backwash discharge (about 10" at most out). The pool, which I'm now cleaning up, has gone from green to brown but has some leaves at the bottom form winter.
    Wondering if I mis-ordered? The PowerFLo Matrix that this pump replaced also had a similar GPM in the 80s or so. Even the lowest 3/4 Doheny has a 62 GPM rating so just trying to figure it out.
    Is this (sand during fist couple of backwashes) normal or did I really mess this one up?
    Thanks.
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Re: New pump - did I overdo it?
    Short follow up. Waded into the pool and there are a few small mounds around the jet.
    mh_jenkins's Avatar
    Jul 2014
    Lexington, SC
    17
    Hi Onslow, Tech talk... I have learned that the pump flow rate listed in GPM (Gallons per minute) should be LESS than the rated Flow Rate of your sand filter. You should check. Also the diameter of your piping is important too. For example 1.5 can handle <=~42 GPM, 2 in <= ~75 GPM, 2.5 in <=120 GPM. If your pump GPM is higher than the sand filter OR the piping diameter, then your motor will labor and will not last as long as expected. Replacing a sand filter is not so difficult, however replacing piping to a pool can be a job. Hope this helps.
    3rd season: 20,000 Gal, IG, vinyl, Sand Tagelus TA40/400 01-L 6 way valve, Emerson 1081 3450RPM motor with Hayward self priming pump housing, Pool built 1997, TF-100 Test Kit , 2009 Plastimayd 20 mil liner (fading), with safety pool cover, Intermatic Mechanical Timer that haven't figured out yet, Pole/hose vac/brush/leaf rake
    --Mike
    May 2014
    SE, Wisconsin
    46
    Sand in the pool would usually mean that it has gotten thru the lateral, generally this would point to a broken lateral. You should not be getting it out the discharge either unless you had a very high flow rate. That being said I think it might be possible that the sand level is so low that on backwash there is no resistance which in turn allows for higher flow rate during backwash, (obviously the level has gotten lower from sand loss as you described)
    .... The other thing that comes to mind is possible channeling in the sand filter.... Have you "deep" cleaned it recently. Be a good time to pull the multivalve valve check the sand level, shop vac out the sand and check the laterals.
    As far as flow rate and your pump you can always get a smaller (less GPM) impeller, it will move less water and it will require less HP. You can safely go to a less gpm impeller and not harm your motor,you cannot go the other way.
    20,000 gal, 18 x 36 IG Vinyl, 1.5 HP Hayward 2610x152S two speed, Sta-Rite S870 sand filter, Raypak 265,000 BTU P-R26A-EP-C, TF-100 Test Kit
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Good advice - thank you both. I'll start the deep clean and see what lies below!
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Quick follow-up to close this thread. Busted laterals, big time. Replaced and all is good now.
    I did send the pump back and replaced with a 3/4hp. Kinda weak stream out but meets the 10 psi recommended on the filter handle label.
