Page 1 of 9 1234 ... LastLast
Results 1 to 20 of 177
Thread: I got my test kit!! Now what!!?
    Baeritto's Avatar
    Jun 2016
    Arlington, TX
    83
    (Salt water pool, **estimated until further notice**12,000 gallons, currently a SWAMP, 3-5 foot deep, DE filter, *i don't think I have a SWG?)
    SWG IG pool, *estimated until further notice* 12k gallons, DE Filter, in ground skimmer, currently a SWAMP.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    434
    Re: I got my test kit!! Now what!!?
    First step, get a full set of test results! Have you been putting in anything?
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    Baeritto's Avatar
    Jun 2016
    Arlington, TX
    83
    Nothing, I haven't touched it. Now, is there somewhere I can look to learn what everything is? I haven't moved anything in the test kit everything sits as it was shipped. But I am not sure what to do with what. I want to create a diagram for not only myself but my family so I can put us on a schedule to do this so we can get the pool clean.
    Baeritto's Avatar
    Jun 2016
    Arlington, TX
    83
    Would it be a better idea to drain my pool and start from scratch? Cost wise? The pool walls have green on them and could use a good scrubbing.
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    880
    Apart from putting up your test results, you need to familiarise yourself with Pool School and the Poolmath tabs above.
    With a green pool you need to also have a read through this article on how to SLAM the pool.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    434
    Read the instructions that came with the kit, and search youtube for videos on how to test. There (probably) is no need to drain unless you have high CYA or CH. Basically you just need to start shocking (SLAMing), filtering, brushing, and vacuuming. But we need test results in order to help with amounts.
    30,403
    1. Somebody needs to catch that shark!!
    2. Read "The ABC's of Pool Water Chemistry" up in Pool School.
    3. Read the directions in the test kit
    4. Perform the tests and post the results.
    Baeritto's Avatar
    Jun 2016
    Arlington, TX
    83
    Looks like pools pretty acidic and chlorine is low
    Baeritto's Avatar
    Jun 2016
    Arlington, TX
    83
    Jezza's Avatar
    Jan 2015
    880
    It actually looks like your pH is high - hard to exactly make it out but looks to be 8.2 which means that it could actually be higher. Add MA and target 7.5 for pH using Poolmath. No surprises that your there is no chlorine without any being added.
    Can you post up the rest of your results. We post test results like this
    FC
    CC
    pH
    TA
    CH
    CYA
    We need all the numbers to help you take the next few steps.
    K-2006
    Baeritto's Avatar
    Jun 2016
    Arlington, TX
    83
    Okay I will post as soon as I learn how do measure the rest. Give me a moment
    Apr 2016
    NC
    109
    I just went through this. You'll want to head to Walmart and grab 20 or so pool chlorine bleach or some concentrated bleach also get some cya chances are high you'll need it. Post results, figure out how to work equipment, and get ready to work a whole lot haha. Good luck. These guys will steer you in the right direction for sure.
    33k IG Gunite, Hayward T-15 Cell SWG, Hayward Sand Filter S210T , Pump Wisper Flo 1.5 HP, Test Kit K-2006
    Jul 2014
    Hope Mills, NC
    566
    Step 1...open beer
    Step 2...only use the pH side of that square tester thing, not the chlorine/bromine side.
    Step 3...follow the instruction card to the letter.
    Step 4...open beer
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Aug 2014
    Northern IL
    4,615
    Dave: Is OP a candidate for tip replacement?
    Baeritto's Avatar
    Jun 2016
    Arlington, TX
    83
    Guys quick, I'm about to give y'all my results but I can't figure out how to test the CC and the FC , help???
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by Baeritto View Post
    Even if the FC is zero, run the CC test, too.
    The rest of the test videos are available here: https://www.youtube.com/user/TF100TestKit/videos
    We're especially interested in the CYA and CH tests. Everything else can be fixed, but if those are way high you'll need to drain some water, so find that out before the first drop of chemical hits the swamp.
    Aug 2014
    Northern IL
    4,615
    Put pool water to the 10 mark in your vial. Add 1 heaping scoop of powder 0870. Swirl well. Add drops of 0871 one by one holding the bottle vertically. Count each drop. and swirl inbetween each drop. When the solution turns clear, add one more drop. If there's no color change, subtract that last drop. Then, using the SAME solution, add 5 drops of 0003. If it is clear, CC is 0. If not, add a drop of 0871 and swirl. Keep doing that until it is clear. Count the drops and divide by 2. That is your CC. Then right away rinse out the vial.
    Baeritto's Avatar
    Jun 2016
    Arlington, TX
    83
    Alright here we go:
    PH - 8.2+
    TC - below .5??
    FC - 0, didn't turn pink
    CC - 0, turned a very VERY pale pink. Hardly noticeable
    TA - about 120-130
    CH - about 200
    CYA - below 20, the sticker never changed.
    Aug 2014
    Northern IL
    4,615
    Okay. Great job!
    Do you have any muriatic acid? (We call it MA).
    Do you have any liquid chlorine or bleach?
    CYA: what sticker? Do you have CYA on hand?
  20. Back To Top    #20
    Baeritto's Avatar
    Jun 2016
    Arlington, TX
    83
    I am writing down how to do all of these tests in my journal I've been writing from what I've learned for future reference so I can move quick next time, give me about 20 mins and I'll tell you everything I have on hand right now. For CYA I mean the little black sticker at the bottom of the test tube. According to instructions it is supposed to disappear. It did not disappear even a bit.
