Results 1 to 15 of 15
Thread: Recommendations for seeing the bottom to vacuum
    Mar 2015
    Mount Pleasant, TN
    59
    Anyone have any hints or tricks to better see the bottom when your vacuuming? I simply can't see through all the surface reflections.
    Pool Stats: 24" Round Above Ground - Vinyl - 13,500 Gallons | Filter: Hayward Sand S180T | Pump: Hayward Power-Flo Matrix | Testing Kit: TF-100 | Mount Pleasant, Tennessee
    Jan 2010
    Randleman,NC
    620
    Re: Recommendations for seeing the bottom to vacuum
    Wait till there is very little wind.Also anti reflective sun glasses
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Aug 2009
    SW Wisconsin
    518
    EASY...I put on my scuba gear, and take the vac head in my hand, and swim underwater, vacuuming up here and there. Works great, and can see everything plain as day!
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Polarized sunglasses. And do it early in the morning or late in the evening when there is less (or no) direct sun on the surface.
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    Quote Originally Posted by flyweed View Post
    You are a man ( or woman) after my own heart!! How many vacuums can you get out of an 80?
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    466
    Nice looking water!! What a nice problem to have
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Absolutely agree. I cannot vacuum without wearing my polarized sunglasses! or you could gently slip into the pool and wear some goggles and do it underwater and have your neighbors think you've lost your marbles, whichever way works
    Also, in my cheapo intex pool i make sure the return isnt pointed up and breaking the surface of the water, that helps a little bit too
    Intex 16'x48" Ultra Frame
    Intex 2,650-Gallon Sand Filter Pump
    Intex Krystal Clear Saltwater Filtration System
    Taylor K-2006
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Another vote for the scuba mask and snorkel! Thats the only way I'm able to do a thorough vacuum job
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Mar 2015
    Mount Pleasant, TN
    59
    Quote Originally Posted by Jamison04 View Post
    I suppose I'll have to go this route as well. The city says I need to install railings around the pool. I won't have side access anymore
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    Quote Originally Posted by Razorhog View Post
    x2 . . .
    Chas & Cheryl (first-time, third-year pool owners)
    Radiant Metric Oval AGP 16'x32'x52"; Pentair: Clean&Clear 150 Cartridge, OptiFlo 1.5 Hp 2-spd, and 320C Feeder (all mounted below water level); Taylor K-2006 & SpeedStir; Maytronics Dolphin E10 (aka Einstein)
    installation pics (2015-2016)
    Richard320's Avatar
    Jan 2010
    18,995
    But there is no cure for sparklypoolitis.
    Casey's Avatar
    SW PA
    10,438
    Keep your return down from breaking the surface of the water. That should help a lot!!!
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by Casey View Post
    YEP,helps alot
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    OMG TFP problems....
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    May 2012
    Montville NJ
    545
    I have teh same problem, but I also have a "sunlight sparkle" liner pattern. Even when udner the water I can't tell which way is up.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
