Thread: Check Valve assistance
    May 2015
    Spring Texas
    22
    Howdy folks,
    Needing some help on where to install a check valve so that my spa stops from draining down.
    would I install it right after the heater ? Thanks in advance.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Check Valve assistance
    If you leave the valve set where it is now, nothing will prevent the spa from draining. I am assuming that the pipes to the left of the valve are for the pool and the port in the valve center is for the spa or is the spa on the right? Hard to tell unless you unbury the pipes.
    If you had the valve set for Spa off and just used the bypass which is the small pipe, you could put a check valve in that pipe to prevent back flow. In spa mode, there should be no back flow.
    Mark
