Thread: CYA loss
    May 2016
    Latrobe, PA
    33
    CYA loss
    What is a normal CYA Loss over a week? I lost 10 ppm from last week to this week. I did a slam last week and everything is great right now. Only losing about 2-3 ppm of chlorine a day. Just curious if 10 CYA loss is normal. It was 45 last week now it is at 35.
    Thanks
    Pool - Above Ground 24' Round by 52" Deep
    Filter - Hayward EC40C92S
    Pump - Hayward 1HP Pump
    Test Kit - Taylor K-2006
    Jun 2014
    15,059
    Re: CYA loss
    Normally we don't experience a big CYA loss each week unless there was a tremendous amount of water exchange. Per "month", maybe 3 ppm or so give or take in areas with intense heat exchange. However, sometimes during a SLAM a pool can experience some CYA loss as noted HERE. Either way, I would simply bump it back to where you need it in preparation for summer and check occasionally as required. Have a nice weekend.
    May 2016
    Latrobe, PA
    33
    Re: CYA loss
    Ok. Thanks. It is still within spec so can I just leave it there and check it again next week? Thanks.
    30,414
    Re: CYA loss
    Yeah, that'll be OK. I'll be a little surprised if you lose that much next week. On average, I don't think your CYA loss will reach 10 ppm.
    Test it next week and let's see where you are.
    May 2016
    Latrobe, PA
    33
    Re: CYA loss
    Will do. Thanks duraleigh
