Thread: Bioguard dealer test results for ADJUSTED TOTAL ALKALINITY?
    Jun 2013
    Bowling Green KY
    16
    My testing with TFP kit #TFP-100 shows TA of 100.
    Bioguard dealer tests TA at 102 but then also shows ADJUSTED Total Alkalinity at 94. Dealer suggests adding 22.5 lbs of Balance Pak 100 to increase ADJUSTED TA to 125-150 ideal range.
    Water is and has been crystal clear for 14 days with TFP kit readings staying consistent: free Cl = 4.0 (3 to 5); Total Cl = 4.5 (ranging 3.5 - 5.5); Ph = 7.5; TA = 100; CYA = 25.
    What is ADJUSTED TA and do I really care if my TFP test kit shows TA in range of 100-120?
    SIZE: 20 ft x 40 ft rectangle; 42in- 8ft; 35K gals IG; Install '75; new vinyl liner '97 (liner now bleached white); 1 bottom drain & 2 skimmers (added 1997); MOTOR: 1 HP 1-speed (replaced 1999); FILTER: Hayward Sand Model S-244T (new 2003); VALVE: Hayward Model SP-714-T1 Vari-Flow (new 2012); PUMP: Pentair Challenger Hi-Head ('75); SANITIZER: liquid chlorine bleach - converted to Trouble Free Pool 2013; Dolphin 2000 Robot cleaner (2003)
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: Bioguard dealer test results for ADJUSTED TOTAL ALKALINITY?
    Hi, welcome to TFP! We don't worry about adjusted TA, just regular TA readings. Really the only reason to adjust TA is to stabilize fluctuating pH levels or drop it to around 70-90 as part of the strategy to prevent scale in extremely high calcium situations. Your TA of 94 or 100 is fine as long as the pH is stable. If you add 22.5 lbs of that really expensive baking soda in the Bioguard package your TA is going to jump up by 46ppm and it will raise pH by .09
    Pool store advice and TFP advice are not very compatible most of the time. Trying to follow both may lead to undesirable results in your pool.
    Love TFP? Become a
    TFP Supporter!
    38,305
    Welcome to TFP!!!
    Run from the over-priced Bioguard products!!!
    Jun 2013
    Bowling Green KY
    16
    Thanks to both moderators for quick reply. As you might be able to surmize from my signature info, I am definitely "old school" on equipment and trying to have my old equipment outlive me.
