Thread: Why higher CYA for SWCG?
    May 2016
    Riverside, CA
    46
    Just trying to understand this part. Is the chlorine produced by SWCG more susceptible to sun loss?
    Also, if I understand the things I've read here, LC does not raise PH but SWGC does. Why is that?
    Appx. 39,000 gal., in-ground plaster. 48 SqFt Pentair DE grid filter, 1 HP Pentair single speed pump, Circupool RJ-60+ SWG (seen here). Currently using Cellulose instead of DE. Hayward XL suction sweep. TF-100.
    38,290
    Re: Why higher CYA for SWCG?
    SWG add FC slowly, higher CYA allows for more protection from the sun and also then lets the SWG not work as hard (use a lower setting) so it should last longer.
    The SWG causes bubbles to form in the cell, this is aeration and that raises the pH.
