Results 1 to 17 of 17
Thread: need help.. zero fc
    Jun 2015
    Greensboro nc
    16
    need help.. zero fc
    Hi I have a 15000 gal in ground pool.. no fc... cloudy pool shocked twice... TDS 2400 CYA 24 fc 0 ph 7.1 alka 170 hardness 201 any suggestions???
    I have a test kit not taylor.. but a pretty good one..
    16 x32 vinyl IG Sand filter Hayward Chlorine pool
    38,251
    Re: need help.. zero fc
    If you do not have the FAS-DPD chlorine test, then the kit is not good enough.
    I am going to guess you got a Color Q?
    You need to follow the ShockLevelAndMAINTAIN Process and that requires the FAS-DPD chlorine test and an accurate CYA reading.
    Jun 2015
    Greensboro nc
    16
    pentair pro 11 Rainbow
    Jun 2015
    Greensboro nc
    16
    thanks
    Jun 2015
    Greensboro nc
    16
    Question... How much bleach should I buy to get a good start on slam??? thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I did a little googling. It looks like that test kit uses the tablets to test FC, and it also says it on;y reads up to 10.
    Problem is, you need to be above 10 FC to SLAM. It's in the prerequisites. You need to have a FAS-DPD chlorine test. Even if your tester could read high enough, it isn't accurate enough to determine when you've passed the Overnight Chlorine Loss Test.
    So before you go off and buy a bunch of bleach, you need to get a proper test kit, or at least a proper chlorine test. It looks like the other tests are pretty much the same as Taylors. Different numbers on the bottles, but probably the same stuff. So you could just add the FAS-DPD tester by itself.
    To answer your question: ten or twelve gallons to start. You can add a jug of standard 8.25% bleach every day to try to keep things from deteriorating, but there's no point in kidding yourself that you're going to SLAM when you're working blind. SLAMming without a FAS-DPD test is like painting a portrait in the dark. You might get paint on the canvas but you won't like the end result. All you'll have done is ruin a canvas and waste paint and time.
    Jun 2015
    Greensboro nc
    16
    Thanks.. I will order it today and try to keep things from getting worse... Does the taylor 2600 work ok? if so I may as well order it.. thanks!
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by jan2227 View Post
    The K-2006 includes that FAS-DPD test. So does the TF100, and it also includes a CYA standard reagent so you can actually test a known value to perrect your technique. It ships from NC, so you'd probably have it the next day.
    Jun 2015
    Greensboro nc
    16
    Help Please!
    Now I have a taylor kit and trying to understand all of it... I have a question about the FC & CC test.. it took 16 drops to turn so that is 32 ppm abd when i added the 5 drops of r003 it turned pink... what is the cc reading??? I know I sound like I'm in the dark.. and I am.. my TA is 15 Cal H 160 and CYA 50.. my pool is cloudy and can barely see bottom of 3ft...
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Jan,
    I am confused. You had this same problem last year and said you bought a test kit then.
    no free chlorien battle...help!!
    Support the site
    38,251
    After adding the 5 drops of R0003, you then count the 871 drops again until it turns clear for the cc.
    What volume of water sample did you use? 10ml each drop is 0.5ppm, 25ml each drop is 0.2ppm.
    Jun 2015
    Greensboro nc
    16
    Re: jan2227
    taylor 2006 I got stumped with the free and combined test... followed along with a youtube... It took 16 drops to clear and 5 drops r0003 it turned pink... how do I get the combine chlorine and is the 32ppm my free? 20,000 gal sand filter
    ph 7.6
    ta 150
    cal 160
    cya 50
    Jun 2015
    Greensboro nc
    16
    yes I did get a kit but it was not a taylor .. pentair pro 11 rainbow... it did not do FAS DPD
    25ml
    domct203's Avatar
    Jun 2015
    CT
    3,577
    25ml
    With a 25ml sample for the FC test, each drop is 0.2ppm.
    Drops X 0.2 = FCppm
    16 X 0.2 = 3.2ppm
    Your FC = 3.2ppm
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2015
    Greensboro nc
    16
    Now that I have my bleach and I know I need to get to shock level of 24 how many gallons do you suggest putting in at one time?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Pool Math will tell you for sure.
    http://www.troublefreepool.com/calc.html
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    38,251
    Yup, time to start using PoolMath ... you are going to have to use it every time you test and add chemicals.
