Results 1 to 13 of 13
Thread: Lowering chlorine
    Jul 2014
    kannapolis NC
    11
    Lowering chlorine
    Could i lower my chlorine by adding ammonia to the pool. Was slaming the pool and guess my son overshot the chlorine by alot yesterday. Its over 50 ppm (stopped at 100 drops it was still pinkish) We have a big gathering tomorrow and was planned on the pool being ready. Its clear with a slight cloudiness in the deep end. I have over 40 gallons of 12% chlorine to fight if it kills too much.
    36000 gallon IG Concrete, Pentair Intelliflo VS , Pentair TA-100D Sand Filter
    38,475
    Re: Lowering chlorine
    I do not understand your last sentence.
    What is your CYA?
    You can use hydrogen peroxide to lower the FC.
    May 2015
    Land O Lakes, FL
    527
    Do you know what your cya is. I read in another thread about using hydrogen peroxide to reduce it. Check into that.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Jul 2014
    kannapolis NC
    11
    Cya is 40, i saw that too just wondering how much it would take to lower to acceptable levels
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    It will lower FC at the same rate that bleach raises FC. Enter your target FC in Now and what you want it to be in Now. Choose 8.25% bleach and that amount of HP will lower FC that amount.
    Jul 2014
    kannapolis NC
    11
    Is it that amount in gallons correct? Guess I'm just getting desperate so was thinking of using ammonia
    DFW, TX
    24,509
    Yes. You can buy HP by the gallon at the drug store.
    Donldson's Avatar
    NW Ohio
    2,916
    Using ammonia to lower FC shortly before a gathering is a terrible idea. It will create a large CC situation that will make your water very uncomfortable. Strong chlorine smell, burning eyes, the stereotypical chlorine pool symptoms.
    Use peroxide or a store bought chlorine neutralizer, not ammonia.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jul 2014
    kannapolis NC
    11
    Quote Originally Posted by Donldson View Post
    Ok thanks for all the help everyone. I "knew" it wasn't a smart idea but very desperate. Thanks again
    No one locally had anything to reduce chlorine as far as pool store related chemicals
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    I hope this is not too late for the party but ahem, pool stores that sell baquacil stuff have HP and they call it shock. Hope that helps.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    DFW, TX
    24,509
    Add your country or state to your location in your profile, I thought all drug stores sold hydrogen peroxide.
    Jul 2014
    kannapolis NC
    11
    Just wanted to say Thank You to everyone. The peroxide worked great needed alot less than i thought. I think my son might have measured wrong. After adding some it went down to 10ppm. Everything was great. Thanks again
    DFW, TX
    24,509
    Excellent, thanks for the follow up!
