Thread: Picky Numbers Question
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    Ok, I just tested my water and have a question. First, I've been on the high side on pH all season. Have added muriatic acid several times. My TA has been in range and still is barely. Here are my numbers today:
    pH- 7.4
    TA- 50
    CYA- 35
    TC- 4.5
    Should I add Borax for the pH and let the TA come on up with it or just let things be since my pool has had pH rise all season so far? My first reaction was to add, but second thought tells me my pH will start to climb again.
    Any opinions?
    SCon36
    24,000 Gallon IG vinyl pool (16x36x8) with Hayward S200 sand filter and Hayward pump and heat pump. Built August 2011. I use a Taylor K-2005 test kit with a K-1515 add on.
    https://www.youtube.com/watch?v=bIgL...0MyAw&index=29
    30,395
    Re: Picky Numbers Question
    Leave your pH right where it is. Monitor the TA carefully, if it drops further, bring it up to about 70 or so using baking soda....nothing else.
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    Thanks! I worry about not taking action and letting it get away vs doing something and end up chasing it up and down. So far I've had good luck with my water in the two years since I switched to TFP. I do my best to get the word out.
    SCon36
    Jul 2016
    Port Orange, FL
    1
    Scon36....drain your pool and move it to Florida. It would do much better there. ��
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    Lol, Angie! I'm not sure I could take the commute to work.
    SCon36
