Thread: Pump Capacitor melted - What to replace?
    May 2014
    Bowie, Maryland
    42
    I opened the pump to run my waterfall and spa jets, Sta-Rite with a #U27-1221 (C48J2PA105C1) motor, and noticed black melted plastic inside the cap and under the capacitor. Have anyone ever had this happen to them?
    I recently replaced that capacitor and I'm sure I replaced it with the same specs as the original capacitor. I'm also sure that I connected the capacitor exactly how the old capacitor was connected. I'm guessing replacing the capacitor is the smart thing to do? Or should I be focusing on replacing the motor or pump? Should I be worried and immediately shut off the circuit or anything else?
    35x18 21,300 Gallon Pool with 8 752 Gallon Overflow Spa || IG || Plaster || DE Filter (American Products) 48 SQ FT || American Model 72 Separation Tank) || GAS Pool Heater (Comfort Zone) || 1HP Jandy || 1.5HP Sta-rite Dura Glas pump || Maryland || TF100 Testkit
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Pump Capacitor melted - What to replace?
    You might have just gotten a bad capacitor. It happens. However, if there is a short in the start winding, that could also be a problem. Do you have a multi-meter? You can measure the resistance across the starter winding (without capacitor) to see if it is shorted.
    Mark
    May 2014
    Bowie, Maryland
    42
    Thank you! I do not have a multi-meter but I will get one and test the start winding and pick up a new capacitor when the stores open next week.
