Thread: Is TA too high?
    FattyLumpkin's Avatar
    May 2016
    Massachusetts
    188
    Is TA too high?
    Hi all -
    FC 6.5
    CC 0.5
    CYA 40
    pH 7.4
    CH 350
    TA 120
    Salt 3800
    Excluding CYA and TA, per the saltwater guidelines page, my numbers look within range for everything. I'm working to get the CYA up to 60-70 -- just added some last night -- but is the TA high enough that I'd want to actively lower it using the acid/aeration method? Will it continue to go higher on its own as the pH goes up with a saltwater pool?
    Thanks!
    / 24k Gal, 18x36 Freeform IG Vinyl Saltwater / Sta-Rite MPRA6E-205L 1HP Pump / Sta-Rite System:3 Cartridge Filter / IC-40 SWCG / Dolphin Nautilus Cleaner / TF-100 Test Kit w/ SpeedStir / Taylor K-1766 Salt Test /
    Useful Links: Recommended Levels / SLAM / FC/CYA Chart / Test Kits Compared / Edit Your Signature
    38,237
    Re: Is TA too high?
    The TA will not raise up unless you add something to raise it.
    Just keep your pH in range and the TA should slowly drop ... or if you have nothing better to do, you could work to actively lower the TA more quickly.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,556
    Re: Is TA too high?
    I'd sure try and lower that as you described to keep PH from rising too fast........which is what your SWG is gonna do naturally anyhow.
    May 2016
    Massachusetts
    188
    Re: Is TA too high?
    Thanks, guys. So the risk of too high of a TA level is that pH will rise more quickly at higher TA levels? Any other risks?
    Apr 2010
    East Texas
    9,556
    Re: Is TA too high?
    That about covers it.
    May 2016
    Massachusetts
    188
    Re: Is TA too high?
    Thanks again. I probably should've checked the ABC page first!
    "At low TA levels, the PH tends to swing around wildly. At high TA levels, the PH tends to drift up."
