Results 1 to 8 of 8
Thread: Cleaning SWG
    May 2016
    near Albany, NY (upstate/central NY)
    27
    Cleaning SWG
    I am very slowly trying to get up to speed on what I should have been doing all along.
    This is the start of the 3rd season for our pool and I've never cleaned (or even inspected!) the SWG (Ironically you would have thought the pool store would have recommended it so they could sell me more stuff for doing it, but even though I asked several times last season as I was dealing with scale in my pool, they never said yes)
    Very nervous about moving/removing any equipment. I read a number of posts here and googled you tube videos for the intellichlor SWG. I have the cap to put on my SWG and the acid. but Baby Steps. I thought I would remove and inspect it first....except that I can't get it unscrewed! I watched the videos closely to see if I was trying to twist it in the proper direction (yes, left loosey..but from which point of view?) From what I can tell, if I stood perpendicular to the inflow pipe , I would turn it left and that I turn it in the opposite direction where the water flows out...(i.e. it would be left if I physically walked to the other side of the SWG and faced it from that direction). So I think I'm trying to turn it the right direction. It is hard to get in there though because the SWG is kind of tucked away in between other pipes.
    Any suggestions on a tool I should use to get it to loosen? I'm not handy at all. not at all. and I fear I would crack the plastic piping or connector or something if I used a tool. but if you do recommend a type of tool to use, can you be very specific? (I don't speak tool lingo so I'd have to google it and then buy it at Lowes). Sorry to be so inadequate!
    Secondly, after the acid wash, where do you guys dump the dirty acid water? I'm thinking I shouldn't pour it down my sink's drain, but also assume it would kill the grass (hmm, maybe I should pour it on some of our many weeds haha)
    Thanks!
    -20'x30'x40' lagoon shaped IG vinyl pool (Nov 2013); 27,500 gallons
    -SWG , Pentair IntelliFlo Variable Speed Pump , DE Filter, Pentair Mastertemp Pool Heater.
    -Municipal water as fill (high pH of 8+)
    -No pool cover and TigerShark vacuum. TFT100
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Re: Cleaning SWG
    Turn as arrows are pointing to unscrew.
    Buying larger wrench to unscrew 4''+ fitting is expensive.
    I use some cheap Rubber Strap Wrench, any big-box store has it, even Wallmart. Search "Rubber Strap Wrench" on Amazon and you'll find it.
    I've actually cleaned my IC-40 this morning (first time in 2 years), there was no build up on blades at all, so cleaning was kinda useless, muratic acid didn't "bubbled" at all.
    Lagoon shape, 23,600 Gal, steel walls by International Swimming Pools, "ultra-seam" liner by Latham, Pentair 011018 IntelliFlo 3HP Variable Speed Pump, PentAir CCP420 filter, Heat Siphon Z575HP, PentAir IC40 SWG, 2 LED Lights (Pentair Intellibrite 5G, 110V). 4 x 1.5’’return lines, 2 x 2’’skimmer lines, 1.5’’ waterfall line. All plumbing is "TigerFlex" pipe, all lines plumbed individually. Deck: travertine glued over concrete.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: Cleaning SWG
    A very large "channel locks" (you can Google exactly that). But be VERY careful using these on plastic. If you feel you are muscling it too much, then give up. I'd rather have a dirty cell than a broken cell and/or adjacent pipe. When and If you get it off, just hand tighten for next time.
    Check your pH at the time you clean it. The fact you have a SWG, chances are you will need MA for the pool anyway. Clean the cell on a day when you pH has crept up above 7.8 Then dump it in the pool when you are done.
    Curious what dilution are you guys using to clean your cells? I started a new thread a few days ago on recommendations for cleaning cells, but no one really cared to input much info. Mind as well put it out there again in case anyone cares to share their cleaning methods. I am always nervous about going too strong that I am going to do more harm to the plates than good.
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Re: Cleaning SWG
    Quote Originally Posted by mikemass View Post
    Pentair recommends:
    Mix one (1) quart of muriatic acid with one (1) gallon of tap water in a plastic bucket.
    If rigorous foaming action does not begin, the blades do not need to be cleaned (STOP THE CLEANING
    PROCESS - go on to step “e). Otherwise, allow the blades to remain immersed in the
    solution until the foaming has stopped. However, do not leave acid in the IECG for more
    than thirty (30) minutes. Excessive acid washing will damage the blades.
    e. Remove the IECG from the bucket and place in an empty five (5) gallon bucket. Rinse the inside and
    outside of the IECG thoroughly with clean tap water and inspect. If deposits are still visible, repeat
    the acid cleaning process.
    It's nice to have a very large "channel locks", but they are expensive.
    Jun 2011
    Long Beach, CA
    2,790
    Re: Cleaning SWG
    With full strength acid use a 4:1 ratio of water to acid for the strongest strength mix at most. You could start at a 10:1 ratio if there is just a little scale inside the cell.
    Never acid wash a cell is you can't see scale as each acid washing reduces the life of the cell by a bit.
    I've never needed a wrench of any sort to get a cell off. If the union is tight, try unscrewing by twisting the cell body. That has always loosened up the unions just enough to unscrew them.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: Cleaning SWG
    Quote Originally Posted by ping View Post
    Yup. That's what I have read multiple times and what causes me to typically not clean the cell when I probably should. The few times over the years I actually have cleaned mine I have gone the 4:1 route. Next time I am going to go weaker and see if it fizzes on the plates.
    Jul 2008
    Seacoast, NH
    253
    Re: Cleaning SWG
    How often do you guys check the cell for scaling. I'm on summer 9 of this cell and have never clean or inspected it myself. My husband tells me that the PB who open and close our pool clean it in one of those activities. Since the "Clean" light has never come on and the SWG has always generated FC just fine, I've never worried about it.
    Am I neglecting my SWG?
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Jun 2011
    Long Beach, CA
    2,790
    Re: Cleaning SWG
    A nine year old cell, I say no harm done. If you don't want to get involved in the details of the equipment no biggie with me.
