Thread: What is the Port for?
    May 2016
    Duncan, Ok
    89
    This port hole has a pretty powerful suction when I turn the valve to open. Is it for vacuuming and should it be on all the time?
    i have 2 holes in my skimmer. Not sure if it's related to this.
    30k Gallons, IG plaster, Jacuzzi Sand Storm 350lb Sand filter, 1hp Jacuzzi Magnum Force pump. Taylor K-2006 kit. Jacuzzi J-D300 side suction vac.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: What is the Port for?
    Yep that's for a suction cleaner.
    Leave it off unless a cleaner is hooked up to it.
    Dolphin E10 Cleaning Robot.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Looks like a suction side vacuum port. Usually there is a flap to prevent somebody from getting trapped from suction. The extra hole in skimmer might be for if the vacuum hose gets clogged the pump still gets water. Leave it off without vacuum, yours is not safe especially for children.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    May 2016
    Duncan, Ok
    89
    I leave it off all the time as I did not know what it's for. Where can I get a cover for it?
    banditig's Avatar
    Sep 2015
    Ohio
    466
