Thread: relay to valve actuator
    Oct 2014
    Rio Rancho, NM
    114
    I'm toying with options to run the valve actuator thru the relay.
    Pentair IntelliTouch i5, i7 and even the i9, only support 3 valves on board. 1 of them is reserved for pump operation. Since I'm using IntelliFlow pump, that output is not used.
    With the expansion module, I got to use 3 more valves.
    I need to add another valve and Pentair T/S tells me to purchase another cabinet called (Pentair 521225 IntelliTouch i5x Expansion Kit), which is not going to happen due to cost.
    I do have all those relays (Aux1-8) that are not being used.
    Question is, does anyone know of a kit to convert relay wiring to valve actuator, or wiring splice kit to run the valve actuator thru a relay?
    I can figure this out, but didn't want to reinvent the wheel if existing solution --outside of the x5-- is available.
    Viking fiberglass Island Breeze II (16'x40'x8'); Pentair pump/filter/heater/chlorinator; IntelliTouch with iX+3; Autelis.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,485
    Re: relay to valve actuator
    Mario,
    I think you will find that the standard Aux relays are SPST and to do what you want, you will need a SPDT relay. I used an additional 120v to 24 v transformer and the Pentair 2-speed relay to do what you want to do. You could use any SPDT relay, but I chose the Pentair 2-speed relay, which costs about $100, just because it is designed to bolt right into the existing relay slots and comes with the coil wire and plug already attached. If you PM me your e-mail address I'll send you a crude schematic.
    Oct 2014
    Rio Rancho, NM
    114
    Quote Originally Posted by Jimrahbe View Post
    Mario,
    Jim, thanks for responding so quickly.
    I agree that SPDT will be the best solution.
    Do you know if/where I can get the 2 pin connector from the relay harness?
    I'm going to use DIN connector and use SPDT and drive my valve actuators that way.
    I'm looking for this connector (male)
    Jul 2014
    Bedford, TX
    7,485
    I don't, but someone here posted the P/N for the red connector a month or two ago. Sorry, but I don't remember who made that post.
    I assume your pool is not a saltwater pool with a SWG... Is this correct?
    This 20 cent plug is just one reason I went with the Pentair 2-speed relay, that and I wanted my modification to look like it like it was supposed to be there..
    Jul 2015
    Central Valley CA
    1,107
    Think THIS is what you are looking for.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Oct 2014
    Rio Rancho, NM
    114
    Quote Originally Posted by atttech-2 View Post
    You're awesome.
    Thanks guys.
