Thread: Filter standpipe (inside) joint sealant/caulk? Need to re-seal, unsure what product.
    threecheese's Avatar
    Jun 2014
    Long Island, NY
    56
    I've had DE getting into our pool since last summer, and have finally found the culprit (after fixing a suction-side leak, replacing o-ring, then grids, then the manifold).
    The caulk on the far side of the standpipe had come off.
    I have to remove this caulk and re-seal the pipe to the elbow, does anyone know what exactly the correct compound/procedure is?
    You can sorta see it, out of focus, in the other attached image.
    30kgal in-ground/steel with vinyl liner, aluminum bullnose coping || 1 H.P. superpump || Polaris P9550 robot|| Hayward 48sq ft DE filter || Taylor K2006 kit
    Jun 2014
    Long Island, NY
    56
    Re: Filter standpipe (inside) joint sealant/caulk? Need to re-seal, unsure what prod
    Hrm, everything appears to be PVC. Blue cement???
    P16_zps0b6bab08.jpg Photo by jblizzle_tfp | Photobucket
    Jun 2014
    Long Island, NY
    56
    Well, if anyone is curious, I bonded the pipe and elbow together with pvc cement, but the fit was way too easy so I supplemented it with plumber's epoxy. I fit it together, it's running, and I will update here once I determine if the fix worked or not.
