Thread: I think I messed up!
    May 2016
    Vermont
    6
    So
    after a few days of rain, i did a full round of testing with my tf100 kit.
    i knew i had to adjust TA and Ph since the last time I tested, but the weather has been so crappy I decided to wait.
    my numbers for today
    FC 5
    CH 50
    TA 40
    CYA 50
    Ph 6.8
    I decided to adjust my TA first and in 48 hrs i'll adjust the Ph
    so i plugged my number in pool math, it told me to add 68oz of baking soda.... BUT i didn't notice the goal was 100!!!!!! So I added way too much if my TA goal is in fact 60-80!
    What do I do now?
    Pool: AG ultra frame Intex 16x48. Intex 3000GPH sand pump, SWG, TF-100 test kit
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    Re: I think I messed up!
    pH is way more important than TA. pH needs to come up immediately.
    Don't worry about TA at all until you can monitor your pH for a week or so.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2014
    15,109
    Hello! Based on those numbers, my #1 concern is the low pH. It's very corrosive right now and needs to be raised with Borax. So use the calculator to get the pH back into the mid-7 range right away. Once you get the pH back to the mid-7s, then re-test the pH and TA. If the TA is at least 50 or so, just leave it alone for now.
    On a side note, watch your FC and CYA okay. You have a SWG pool, so your CYA should be at least 70 to protect your FC.
    May 2016
    Vermont
    6
    Thank you.
    I just added borax. I will retest tomorrow
