Thread: Won't calculate
    Jun 2016
    Magnolia, Tx
    1
    Won't calculate
    The pool math won't calculate for me. What am i doing wrong
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,087
    Re: Won't calculate
    Did you put in your pool's size in gallons, the current value in the left column and the desired value in the right column?
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jan 2014
    Buckeye AZ
    807
    Re: Won't calculate
    put your pool gallons in first, no commas! At the bottom of the calculator, select the troublefreepool.com option in the drop down for selecting target levels.
    In the left column of every category, the NOW column, put your current test result. When you TAB away from the field, or click to another field, that NOW column will be set.
    The target column is set already, bu may change depending on other entries. So when you add your current CYA reading in the now column for CYA, your target FC level will change appropiately. YOu can also manually change target levels if you need to get somewhere other that the standard targets (for raising FC to a SLAM level for example)
    Finally, pool math will instantly compare your NOW to your Target, and then show you in the text field to the right of the now/target, what you need to do to get from NOW to Target.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Won't calculate
    Welcome to TFP!
    If those suggestions don't help enough here are some official instructions. Pool School - PoolMath
