Results 1 to 7 of 7
Thread: How to determine the strength of your bleach?
    Her pool boy's Avatar
    May 2016
    St Catharines, Ontario, Canada
    90
    Hi. Have a bit of a head scratcher. I added enough bleach last night, according to pool math to raise my FC by 2. But It only ended up raising the FC by 1. My FC was 2 and 90 minutes after adding it measured 3. I measured again this morning and got 3. I know bleach loses strength over time, I am just wondering if there is a way to measure the strength of the bleach.
    I am am also pondering whether whenI measure 3 last night The chlorine hadn't mixed completely, and it got to 4 overnight and lost 1 FC before I measure this morning but don't think that is likely because I haven't been losing 1 FC over night.
    i suspect bleach strength but don't want to assume anything, then over chlorinate. Is there a way to test? that is the question..
    Readings this morning are
    FC 3
    CC 0
    pH 7.6
    TA 100
    CH 150
    CYA 35
    SteveS
    16' x 50' - 95K L (25000 gallon) I.G. Vinyl liner 12.5 Liquid Chlorine
    Wicor Pantera P24 Sand Filter Pentair Superflo Variable Speed Pump
    Zodiac 3510WD Robotic Cleaner Raypak R336A Heater. ​Taylor K2006c test kit
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: How to determine the strength of your bleach?
    I did a bathtub test one time. Seemed to work pretty well. I used the bath tub and pool math to calculate bleach strength
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Two options.
    See the directions in this post: Commercial bleach: testing concentration
    Or... Taylor has a test kit to test the strength of bleach. Welcome to Taylor Technologies Not sure its worth $100 to you though.
    Isolated Spa - 345 Gallons
    May 2016
    90
    The reading links were very helpful, I think I like the chem geek's method, and based on that my bleach is currently at half strength.
    SteveS
    phenol red's Avatar
    May 2016
    Twin Cities, MN
    22
    Keep in mind that bleach decomposition rates can be predicted:
    Breakdown of bleach over time by storage temperature - Page 2
    30k gal in-ground, vinyl liner, Hayward 300 ft2 cartridge filter, 1 hp pump, Hayward 250k btu natural gas heater
    May 2016
    90
    Thanks red...it now all makes perfect sense.
    SteveS
