Thread: Low Flow on SWS
    May 2016
    Lumberton TX
    8
    Low Flow on SWS
    We just set our pool up recently and haven't even used it yet. I have a couple of other threads going on chemicals, etc....
    Yesterday, we added an SWS to our Sand Filter Pump. I followed all the directions and let the sand filter run for 24 hours like it said.
    This morning, I went to turn the SWS pump on and for a few seconds, everything was okay. Then, it began beeping and said "LOW FLOW".
    I turned everything off and went through the process that I had to do when I first hooked up my sand pump (let the air out of the valve, etc....), but when I turned everything back on, I still have the same problem.
    I don't know what to do now.
    Help???
    Intex 18x9x52 Above Ground Rectangular Vinyl Pool
    4545 Gallons of city water
    Intex Krystal Clear Sand Pump and SWS
    Installed on our property 5-29-2016
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Low Flow on SWS
    Hi ,
    What pump are you running
    What is the pressure on the filter at?
    If the flow is to low the SWG will not turn on (safety)
    May 2016
    Lumberton TX
    8
    Re: Low Flow on SWS
    We figured it out. It needed to be backwashed! Thank you though.
