Thread: Cleaning Bottom of Intex 14 Round Pool
    May 2016
    Fl
    18
    Does anyone have any cost efficient and effective ways of cleaning the bottom of their Intex above ground pool? We have the standard pump so I don't think the traditional vacuum would work? We are having a small party tomorrow and would like to get the pool clean as possible! In walmart I saw a manual vacuum where you attach to a pole, does anyone have any experience with those?
    Thanks!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    Re: Cleaning Bottom of Intex 14 Round Pool
    I've used a traditional vacuum before, but rather than running it back through the pump, start it siphoning and just let it run onto the ground. It'll have a surprising amount of suction. Then top off with fresh water.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jul 2015
    Georgetown/DE
    7
    I use the intex one that hooks to end of pole and connect water hose to it. It picks up the debris very well. You will have a hard time with small stuff like sand but it works.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Put the kids in the pool and have them run around the edge and create a whirlpool before you pull them out. All the debris will settle in a pile in the center. Then you can siphon vacuum quickly and lose the l;east amount of water.
    Also, for a big party, raise the FC 2 or 3 points above normal before people get in and again after they get out. And don't panic is the water looks a little blurry and CC rises after the party. It's only temporary if you've been good about maintaining things. It'll recover in a day.
