Thread: Did Hayward fix the motor/drive issues on the Ecostar?
    Apr 2016
    Chalfont, PA
    26
    I'm thinking of getting the Hayward Ecostar but have read a ton of negative reviews about the motor failing? Has this been corrected or are people still dealing with that issue?
    30,000 gallon In-ground pool with spillover spa
    Omnilogic, SWG (Hayward T-15 Cell), Hayward actuated valves and Raypak Heater
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Did Hayward fix the motor/drive issues on the Ecostar?
    I think the reason most of the failures occur is because they did not install a power surge protector with the pump. This can and does happen with all VS pumps and not just the EcoStar.
    Mark
