Thread: Just drained 95% of my pool. Can someone give a quick sentence or two on how to SLAM?
    Jun 2014
    Houston, TX
    22
    My CYA levels were around 4/500 after years of bad managing the chemistry. I just drained about 95% of my pool (just enough to keep the pumps going), and is currently filling back up.
    Can someone give a brief summary on how to SLAM? I read the guide here, but just wanted to confirm I'm doing things right after draining so much.
    -Approx how much bleach or chlorine to buy for a 8000 Gallon Hot tub?
    -Getting the PH to 7-8 is KEY before SLAMMING, correct? (leave all others alone)
    -After getting the PH up, the only chemical I should be using is bleach/chlorine right? (turn off the bromine feeders currently set at 1)
    Once my chlorine levels stabilize, then I can do everything else to have a good balance, right?
    -Whats the recommended way to lower my extremely high chlorine after it stabilizes (aka: I can stop the SLAM method; chlorine doesnt drop anymore)
    Thanks guys! looking forward to a blue tub again after so long of green tubs
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Just drained 95% of my pool. Can someone give a quick sentence or two on how to S
    I think this is a swim spa, correct
    With a 95% drain you're basically starting over with new water so this should be easy, you may not even need to SLAM unless there is algae still in the pool/spa.. recommended levels Pool School - Recommended Levels, get everything balanced and see if you need to SLAM
    Try this, I think it will help do exactly what you're trying
    How do I use Chlorine in my Spa (or pool)?)
    Jun 2014
    Houston, TX
    22
    Quote Originally Posted by cowboycasey View Post
    swim spa? Lol, I always thought of it as a really long hot tub. It's 4.5ft high and just.. long.
    These same methods should still work even though I want to switch from chlorine to bromine tablets to maintain in the future correct?
    Jul 2013
    Fletcher, OK
    3,353
    should be no issues but most stay with chlorine because it works so much better... I could never get my bromine to work correct
    But the SWG is working like a champ
