Thread: Bromine pool causing a cough?
    Dec 2010
    Bluffdale, UT
    14
    We have an in ground, vinyl lined pool ( about 35,000 gal) that was installed 18 years ago. 4 years ago, we had the liner replaced ( and hence, all the water). In the last year and a half, we have noticed that when we are swimming, we all start coughing a lot. We didn't have this problem prior, but I am wondering if it related to the bromine? We had a suction side air leak that caused bubbles in the pool, which has now been fixed, but we still cough. It seems to be worse when we first open the pool cover, or when there is a lot of splashing.
    Total alkalinity, ph and bromine levels are all normal ( although total alkalinity was a little low the start of the season). What should I be checking? Could this be high combined bromine? If so, should I try opening the cover and aerating the water? Shocking? Other?
    Any help will be appreciated
    Re: Bromine pool causing a cough?
    How many pounds of bromine tabs have you used since the liner was replaced?
    Is this an indoor pool?
    Support the site
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,777
    Mj, that's how I react to bromine, which is why, in my hot tub, I switched. Not sure in a pool setting what works, but I know that nothing short of switching to chlorine worked for me in the hot tub.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
