Thread: Dips in vinyl covered steps
    Jun 2016
    Muskogee,OK
    2
    Had new pool constructed recently with vinyl covered steps. Visibly the steps look good. However you can feel several areas where the step has a dip in it. Is this normal for this type of steps?
    Apr 2013
    Sacramento, CA
    2,769
    Re: Dips in vinyl covered steps
    Is this sand or something else making up the bottom? If its concrete or vermiculite there should be no dips or softness. I would ask the builder to come look.
    Jun 2016
    Muskogee,OK
    2
    The steps are vermiculite. Thank you I will have them look at it.
