Results 1 to 15 of 15
Thread: TFT Pressure Gauge
    Apr 2010
    Central NJ
    227
    TFT Pressure Gauge
    I purchased the bottom mount pressure gauge from tft, I believe it was last year, and since day one it's been inconsistent. For example, it could read 20psi, turn the pump off and on, then it's at 17 and a few minutes later it will be at 20. Other times it behaves as expected, which would be for it to read 20 again. Sometimes when I turn the pump off, it slowly goes to 0, most of the times it goes straight to 0. Other times when I turn the pump on it slowly rises, most of the times it climbs right to, what I assume, is the correct psi. Did I get a dud? is there something I can do to try to correct it?
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: TFT Pressure Gauge
    I am NOT an engineer but that doesn't sound wrong to me.
    Keep in mind that filters are dynamic... you will have different amounts of debris and pressure at different times.
    If I plug in my Polaris the pressure is higher than if that return is left wide open, and if I need to backwash it will also be higher.
    Yet you're ultimately getting the same reading in minutes of 20, right? It just takes a few minutes?
    Apr 2010
    Central NJ
    227
    this is only my second gauge I've owned for the pool. i would think that with all being the same the reading should be the same. it shouldn't take the pump a few minutes of run time for the gauge to read what it was reading previously. the pressure should be the same almost instantaneously, i would think. it's the same pump, same filter, same amount of debris as when it was when turned off, so it's not really dynamic, with a quick off and on cycle. and keep in mind, this only happens sometimes, most of the times, it reads just as it did before I powerded if off. Besides, how about all of the other scenarios I mentioned? it just isn't consistent.
    Jan 2012
    7,367
    But...but.. doesn't the DE fall a bit off the fingers when the pump is off? Do you ever bump the filter? I would think those times the pressure would vary even briefly.
    Remember.. I'm a trauma nurse, not an engineer
    I'm just trying to use a few brain cells to critically think this through with you.
    JoyfulNoise's Avatar
    May 2015
    13,247
    It is possible for these pressure gauges to get debris lodged in them. I've see gauges act screwy when someone used Teflon tape on the threads and accidentally covered the hole a little.
    Take the gauge off and see if there is any debris plugging the hole. Unfortunately if debris has gotten into the gauges, they can be impossible to clean out. You may need a new one.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Drop them an email at TFTestkits@gmail.com or give them a call and I'm sure they will be happy to help you solve the issue.
    22,553
    As Matt eluded to, it sounds like debris in the connection port or the bourdon tube. It's possible that there's something in the pointer mechanism, but since those are filled gauges, that's doubtful.
    DaneCE's Avatar
    Jul 2011
    VA
    279
    I've had 3 of these gauges fail on me in about 2 years. 2 of them were replaced for free with great customer service. My current gauge has worked on and off for 3 months but has gotten worse. I can do without a gauge so I just ignore it now.
    Apr 2010
    Central NJ
    227
    three fail in two years?! That does not sound promising for me! I will remove mine during the weekend, clean it and re-install it. The one I replaced looked like it was original (15 years?), I expected to at least get a few years from this one.
    Oct 2015
    Katy/Texas
    411
    I have a TFP sourced gauge and it works flawlessly. I doubt that the perceived problem is with the gauges. Check and make sure that there is nothing obstructing the gauge port, such as Teflon tape or pipe thread dope. Your history with gauge failures suggest that it really is something other than the gauges that are failing.
    In ground, 14,000 gallon, white plaster, unheated, stone waterfall, DE Filter, Rainbow 320 Cl, Polaris 3900, FloVis flow meter, F100 test kit, Circupool RJ30+ SWG, Circupool VJ1/Speck Badu EcoM3V variable speed pump.
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,154
    Please send me an email at tftestkits@gmail.com and I will get your gauge issue resolved or send you a new one. Thanks! Rebecca
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Quote Originally Posted by WASP View Post
    +1
    I was looking for a reason to get one and my new house/pool had a broken plastic gauge.
    I replaced it with a tfp gauge last september and worked perfectly since day one.
    Dolphin E10 Cleaning Robot.
    Jan 2012
    7,367
    Do you leave your gauge on the filter over the winter? Could that be an issue for you?
    38,470
    I notice that with the large temp differences, the needle sometimes does not go to 0 when the pump turns off. But quickly opening the plug on the top equalizes things back out.
    DaneCE's Avatar
    Jul 2011
    VA
    279
    My first 2 gauges got stuck at around 20 psi. My current gauge sometimes stays at zero or only rises to 10 psi when it should be a few psi more. I thought it could be a filter problem but last Spring I did a deep clean(it was fairly clean) and removed all of the sand to inspect the laterals and everything looked great. I don't use thread tape or dope.
    I use DE for 3 months out of the year. I don't have a lot of junk falling into my pool or much sunscreen oil. I'm just thinking about anything that could gunk up the gauge but I really have no clue as to why I've had such bad luck with mine.
