Thread: Pump not priming to waste
    Jun 2016
    Louisville/KY
    2
    My pool pump will not prime when set to waste. It primes with no issue when set to filter. I changed my sand and multi port valve today but that did not fix my issue. Does anyone here know a solution or anything else I could try? I'm at a loss at this point!!!
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,763
    Re: Pump not priming to waste
    There might not be enough restriction on the discharge side of the pump and it is cavitating while trying to prime. Do you have a valve on the waste side you can partially close to restrict the flow until the pump primes? With no restriction and smaller diameter lines on the suction side, it would be fairly easy for the pump to run away from itself.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Jun 2016
    Louisville/KY
    2
    Thank you Brian. My lines are the same size. So I don't know if that's the issue but I will try restricting the flow on the waste side.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Why are you trying to prime on waste?
    Mark
