Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: New Build - Long Island NY
    May 2016
    Stony Brook
    16
    Hello Everyone!
    Glad to have found this site! I'm in the 1st stages of planning a new inground pool. 1st problem we encounters is our overhead electric. Looks like we're going to have to bury the line since it crosses over my backyard. Anyway I'm hoping to get some intial feedback about pool shape and size. Retangle vs mountain pool. And 14x28 vs 16x32. We're kinda limited with the width since my backyard narrows at one point to 38'. We need to be 15' from neighbors / fence as per Brookhaven town regulations.
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Re: New Build - Long Island NY
    Hey there Albenda Welcome to TFP. Make sure to bookmark this site because you'll get lots of ideas and help here through out your building process and after. (and we *love* pics of pool builds. I call it pool-porn)
    I personally feel a rectangle pool gives you more usable room in a pool for games and actual swimming. I liken it to a "classic shape"
    The curvy pools can be aesthetically pleasing but you lose some space and they are more difficult to cover in your cold winters. Either way I'd say get as big a pool as you can fit in! And lots of pool decking around it.
    You may want to consider now how you want to sanitize your water (salt water generators are *very* popular) and you will want to consider your pool depths. Shallower for more play, deeper for diving and swimming? What sort of things do your family like to do in a pool?
    Again, wellcome to TFC and bring on any questions, 'k?
    Yip
    May 2016
    Stony Brook
    16
    Thanks for the tips �� Not sure what depths yet. It is more of an adult play pool if there's such a thing lol.
    Aug 2014
    Houston tx
    2,524
    Oh, there most definitely is!
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jun 2015
    East Meadow/NY
    82
    Good luck!
    14x22 radiant freeform, 6800 gallons, Semi AG, DE Hayward, Hayward SP1580X15 Power-Flo LX Series 1-1/2-HP, installing 7/14/2016, TF100
    May 2016
    Stony Brook
    16
    What is the width and and depth for a diving pool?
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    There's not a short answer to that question. Here are the details to determine your diving envelope based on your pool type. Drastically simplified, the depth required is around 8' unless your diving platform is very high off the ground (deeper is always safer in that regard). And that depth must extend out a certain distance. Then the slope must not exceed X over a certain length. Then you want a shallow area of some size. Generally the very shortest you will see a diving pool is around 32' - 34' long to accommodate those requirements. And not usually skinnier than 15'.
    http://www.divingboardsafety.net/06-...i-standard.pdf
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    May 2016
    Stony Brook
    16
    Thanks- that was helpful.
    May 2016
    Stony Brook
    16
    16x32 build begins in 3 weeks...
    May 2016
    Stony Brook
    16
    Anyone use solar panels for inground pool?
    Jun 2016
    Port Jefferson Station
    49
    I do I'm I'm next to you in port jeff sta I just installed them this year and they work awsome I would definitely recommend this
    May 2016
    Stony Brook
    16
    Great! Where did you get them?
    spoonman's Avatar
    Jun 2016
    Peoria, AZ
    241
    Wow, that was fast!
    Im putting in a 14x28 rectangle similar to you. I'm going down to 6 feet for activities, but not deep enough for diving (pool isn't quite long enough).
    looking forward to seeing your pool progress. What are you doing for tile, concrete, etc?
    14x28 IG Rounded Rectangle, 6" aqua tile, White plaster, Gray Acrylic deck, 4' Baja Step (18"), aerator jets, 3-step InterFab SS Ladder, Pentair Intelliflo VS Pump, Pentair TR100C Sand Filter, Stenner Econ E10T2A (chlorine), K-2006, Zodiac Baracuda G3 pool cleaner
    May 2016
    Stony Brook
    16
    Yeah they ripped it up fast considering all the roots in my backyard- a full truck load UGH! I had a large oak and pine tree removed last year. I'm thinking a concrete deck, stained gray. My pool contractor told me to wait until next spring after the ground settles ...
    Its a Vinyl lined pool.
    Jun 2016
    49
    My panels are made by enersol and there great
    Nectarologist's Avatar
    Apr 2015
    New York
    427
    Quote Originally Posted by Albenda View Post
    I waited until the next spring to put down patio. If I may suggest, buy cheap tarps at the store and cut it into strips 2 - 3 feet wide and pay them around the edge of the pool (pin down with landscape pins or even rocks). I learned the hard way that once the dirt puddles into mud the water that splashed up during a moderate rainfall will be muddy water The pool water literally turned brown right before my eyes (took a day to filter it clean). Once I laid down the tarp it wasn't an issue. You could also lay a truck load of pea gravel. I put a 4x8 piece of plywood at the stairs with an outdoor carpet over it. It was amazing to see the drop/settling of the backfill after the first heavy rain! We could have laid a patio in October/November as it seemed to settle all is was going to but I was glad to get a winter's worth of snow on it melting just to be sure. Plus I had budgeted to do the patio that next spring (went with pavers on 1/4 and grass on 3/4 of it).
    Inground, vinyl liner, 16 x 32 (approx. 21k gallons), roman end w/ bench, 2 Jandy LED lights
    Pump: Jandy Flopro, 1.5 hp Heater: Raypak, 266k btu (P-R266-A-EN-C; nat gas) Filter: Jandy C340 (cartridge filter) Robot: Doheny's Dolphin Discovery SWCG: Circupool RJ45
    May 2016
    Stony Brook
    16
    Ok thanks. I'll check it out, for next year though. I'm already over budget. Lol
    Pool: 16x32 IG Vinyl lined rectangle pool. Liner: Megna Pools Waverunner, Deck: possibly concrete TBD
    May 2016
    Stony Brook
    16
    Yikes! I'd die if my pool turned brown. Lol. Great info...thanks. I'm a newbie to this, so I really appreciate. I thought about outdoor carpet grass but never considered the tarp. Good idea.
    May 2016
    Stony Brook
    16
    So I had to bury my electric line that ran across my backyard. If anyone needs info on this.
  20. Back To Top    #20
    May 2016
    Stony Brook
    16
    Hey there. question, can you install the panels on shed roof?
