Thread: Pump for a 12x30 frame pool
    Jun 2016
    Nichols New York
    5
    I'm hating the filter pump that came with our Summer escape 12x30 metal frame pool. Can anyone recommend a pump system that I could replace it with?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pump for a 12x30 frame pool
    Welcome to TFP
    Those aquarium pumps that come with that pool are garbage, I can not believe they get away with selling those...
    I would recommend going to an intex system instead, they are great compared, you will need to order a few things below... I would also get a saltwater system (SWG) as they are very easy to use and also make its own chlorine
    here is a SWG system
    Amazon.com : Intex 120V Krystal Clear Sand Filter Pump Garden
    the 2800 gallon non salt system, you will need to add bleach daily with this system
    whatever pump you go with you will need these to convert over
    Amazon.com : New Model Set of 2 Intex Large Pool Plunger Valve Assemblies : Swimming Pool Pump Accessories : Patio, Lawn Garden
    Amazon.com : Large Intex Pool Strainer Assembly : Swimming Pool Maintenance Kits : Patio, Lawn Garden
    Amazon.com : Intex 1.5 in. Large Pool Inlet Nozzle Assembly : Toys And Games : Patio, Lawn Garden
    I hope this helps
