Thread: rain and the pool
    rain and the pool
    hello all. just moved into a house with a pool, this is our first experience with one...
    i live in florida and it has been raining for 2 days straight and the pool water level is
    very high, is this ok? should i keep everything running as usual?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: rain and the pool
    Hi jmedeiros and welcome
    I suggest you lower the level to mid-way or so of the skimmer.
    What kind of pool/equipment do you have?
    You're done SLAMing when:
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    It would be good to give us a bit more information about your pool and current test results. It might be good to increase your chlorine level, but since I don't know your current levels it's just guessing. But that's what many people do, in anticipation of storms/rain, increase the FC level.
    Welcome
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    if you live anywhere in central florida, I wouldn't lower the water personally, as there will probably be plenty of non-rainy days that will eventually require you to add water (assuming you use the pool at all and have splash out, plus evaporation). since we're in the umpteenth year of drought (or are there just too many people here?) I am leaving my pool very full to conserve water later. if you are going to drain no matter what, I would do it just enough that the skimmer can collect the junk off the top of the water.
    Apr 2009
    Sarasota Florida
    143
    Quote Originally Posted by reebok
    might want to drop is some because in sw Florida we are expecting rain for the rest of the week. I dropped mine some on Sunday. Otherwise it would be overflowing today.
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
