Thread: Chlorine/cya chart
    Jun 2016
    Water valley ms
    7
    Chlorine/cya chart
    Hello, could someone explain how to use this chart? My cya was 70 yesterday have not tested today. I feel like I may need to practice this test a couple of times. Thanks for the help still reading info in poolschool
    16x30 in ground,vinyl liner, sand filter
    Tf 100 test kit
    38,239
    Re: Chlorine/cya chart
    Given a CYA of 70ppm, you need to keep the FC above the minimum (5ppm) at all times ... that is the most important thing to realize from the chart.
    Note that CYA does not change very quickly unless you are replacing water. May only need to test once every few weeks or a month.
    Jun 2016
    Water valley ms
    7
    Thanks Jason so keeping fc up is that where I add bleach
    Tf 100 test kit
    38,239
