Thread: High PH, High TA... thought I had mustard algae. ;)
    May 2014
    Montgomery, NY
    22
    So silly me thought I had mustard algae.... weird yellowish/light brownish substance in the bottom of our Crystal clean pool. I shocked (according to pool math to MA levels) and brushed it. Did the overnight test and lost 0 chlorine. I suddenly realized my solar cover, deck, grill and car were COVERED in a pollen film. Totally felt silly.
    3 days later I've barely lost any chlorine. My ph is 7.8 maybe 8 hard to tell and my TA is 140. I already have some acid on hand to tackle that issue..but my question is...
    should I let the chlorine level go down before adjusting TA so I don't drop the PH too much? I have read with high chlorine the PH can look misleadingly high...I'm loving the accuracy of this k2006 kit!
    AG Intex 16'x48" ultra-frame pool. 16" intex sand filter.
    Jun 2014
    15,267
    Re: High PH, High TA... thought I had mustard algae. ;)
    Yes, let the FC drop below 10 so you can get an accurate pH reading before going to far. Good luck!
