Thread: Floor drains have algae below the grate
    Sep 2015
    alexandria/ky
    14
    My floor drains have 3 screws holding the cover on. Can I remove these screws during normal operation and scrub this algae with a tooth brush?
    12K, 14x28 rectangle vinyl in gound, Pentair superflo pump, Pentair C&C RP cart filter, Aquarite SWG
    38,301
    Re: Floor drains have algae below the grate
    Sure.
    Is there flow going through the floor drains? Algae would point to stagnation if you are maintaining normal adequate FC levels for your CYA level.
    Sep 2015
    alexandria/ky
    14
    I always have the drains open and my last FC was 6 and my cya is about 60ish
    38,301
    6ppm is the minimum for a CYA of 60ppm, you should be keeping it higher ... unless you have a SWG ... but there is no way for me to know that since your signature is blank
    Please add your pool details to your signature as described HERE as it will help us help you.
    Wait, your sig is in the first post, but not the 2nd ... weird.
    So 6ppm should be fine with the SWG.
    Sep 2015
    alexandria/ky
    14
    No worries, and thanks, I wasn't sure if taking the covers off the drain created a leak or something worse.
    38,301
    Oh ... hmmmm ... I would assume you can take a cover off the vinyl floor drain and not lose the seal. But I am not sure of their design, so I would wait for others with knowledge to confirm.
