Results 1 to 8 of 8
Thread: Draining spa into pool
    Jun 2016
    Scottsdale, AZ
    6
    Split by moderator from HERE. Please ask questions in your own thread. Thanks, jblizzle
    Hi!
    We have the same problem except it happens every day when the pool turns off. We replaced the check valve today and it didn't help.
    Not familiar with a 3-way valve. Can you explain?
    Thanks!
    Jun 2016
    Scottsdale, AZ
    6
    Re: Spa keeps draining into pool
    My husband has put new O rings on all the valves.
    Here is a picture.
    The left top and bottom is pool operation. The right is spa operation.
    Apr 2009
    Northern Virgina
    55
    azsunshine2016,
    If the blue arrows in your pictures are meant to indicate water flow, you should know that they appear to be incorrect in the bottom two pictures. I'm assuming that the top pictures show the suction side valves (going from the pool/spa into the pump) and the bottom pictures show the pressure side valves (going from the pump to the pool/spa).
    In the case of the lower left picture (pool operation), the water flows to the right out of the upper three-way valve (not to the left) and then is split evenly between the wall and floor jets by the lower three-way valve.
    In the case of the lower right picture (spa operation), the water flows to the left out of the upper three-way valve (not to the right) so there is no need to change the position of the lower three-way valve because no water flows to those pipes.
    22k gallon IG Anthony free-form pool and spa with PebbleSheen finish, Pentair WFDS-8 WhisperFlo Full Rated Dual-Speed 2HP pool pump, Sta-Rite S8D110 System 3 Grid D.E. 53 sq. ft. pool filter, Raypak R406A 399K BTU cupro-nickel propane heater, Polaris 280 pool cleaner with 3/4 HP PB4-60 booster pump, Goldline Aqua Plus controller and SWG, Inter-Fab G-Force pool slide.
    Jun 2016
    Scottsdale, AZ
    6
    Re: Draining spa into pool
    Jim.... Maybe explaining how we operate the pool may help.
    When in running mode, we have most of the water returning through the spa so it spills over the spillway into the pool. So the pool return is pretty much off.
    The left photos top and bottom are pool operation.
    The right photos top and bottom are spa operation.
    The valve that says "do not touch" simply adjusts the suction between the pool cleaner or skimmer basket.
    Hope that clears things up.
    The pool has worked great for 20 years. We just have this issue recently of it draining into the pool only when all the equipment is off.
    triptyx's Avatar
    Apr 2016
    1,438
    I think I understand what she's saying. The blue arrows don't demonstrate water flow, I think she's using them as a "pointer" to indicate which way the valve points.
    Is the black cylinder inline with the white pipe in the lower right corner of the bottom two images a check valve, and if so, is it possible that that valve has failed, hence the spa draining into the pool through the returns?
    I have a similar problem, except I don't have any check valves in my system - I've been contemplating adding one or more.
    You could experiment by running the pump in "pool mode" for a bit until the spa starts to overflow, then put the valve marked "Spa Operation" into the opposite setting as it is pictured, shutting the pump off immediately after closing it. If the spa doesn't drain, I'd think that was your problem.
    Edit - to be clear, I'm suggesting that you put all valves into "pool operation", run the pump, let the spa overflow, then just turn the valve labeled "spa operation" to the opposite side as it is pictured in the spa operation image - which should cut off all water flow to the spa return, putting all water through the pool returns. Then shut off the pump. If that is a check valve, and it's bad, having that valve shutting off the spa return line should verify if the problem is with the spa return line.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Jun 2016
    Scottsdale, AZ
    6
    Also moved from the other thread. Keep your posts in your own thread. jblizzle
    Spa is fixed! We had a broken diverter in a jandy valve. Spa is holding water and pool pump is off!
    Thank you!
    triptyx's Avatar
    Apr 2016
    1,438
    Glad to hear it. Enjoy your weekend!
    Jun 2016
    Scottsdale, AZ
    6
    Sorry! I thought I was. I also thought threads were topic based, not user based. Sorry again!
