Thread: Filters
    Jul 2015
    Poway, CA
    58
    Filters
    Hello,
    So I started my SLAM yesterday and it's going good, but I have a question. Do I need to clean the filters again after the SLAM since I just cleaned them before I started? My water wasn't crystal clear, I was getting a little yellow algae on the sides of the pool and it was using more chorine than usual.
    Thanks for your help!
    27K Gal, IG Plaster, Hayward EcoStar Variable Pump, Pentair DE FNS Plus Filter 24, Hayward AquaRite with extended life T-CELL-15
    The Pool Cleaner Sweep
    Build in 1969
    Water From City
    TF-100 Test Kit
    38,548
    Re: Filters
    You should clean the filters when the pressure rises 20-25% over the clean pressure.
    If you are filtering out algae, it would not really hurt to clean them at the end of the the SLAM too.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Filters
    When your pressure rises 25% above the pressure it was when it was cleaned, it's time to backwash and recharge. This is regardless of during a SLAM or during normal maintenance.
    Isolated Spa - 345 Gallons
