Thread: New owner of a green pool!
    Jun 2016
    Newburgh NY
    12
    After stalking the forums for awhile, I've decided to join! I purchased a home last summer with an 18x36 30,000 gallon inground pool. It was already open and we had no issues all summer other than constantly battling algae. We opened this year more than a week ago and it was a little green and cloudy but we couldn't get the pump running. After a few days, we had the sand changed in the filter and realized it was the capacitor that was the pump issue. In those few days, the pool became very green!! Pool guys said to put 8lbs of shock in and check 24-48 hours later and vacuum to waste. It got a little better with the shock but we added more. That was 2 days ago and it's still green. We have also been getting rain, which doesn't help!!
    My question: do we vacuum to waste even though we can't see the floor? We've been back washing, but that's it.
    Do we brush the sides or will that just stir it all up? I have no idea what to do. Help!
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: New owner of a green pool!
    Until your test kit arrives (you did order a test kit didn't you ) just scoop best you can, then when you can't get much more "stuff", run the filter in recirc for a little bit and add a bottle of bleach. I wouldn't risk sucking up something you can't see.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2016
    Newburgh NY
    12
    We heard different things about vacuuming without seeing the bottom, so we decided not to. Waiting for the test kit!
    18x36 inground vinyl. 26,000 gallons. Hayward s200 sand filter. T100. Southern NY (Hudson Valley)
    Jun 2016
    Newburgh NY
    12
    We heard different things about vacuuming without seeing the bottom, so we decided not to. Waiting for the test kit! About the bleach, we can just pour it in the pool? Is that better or the same as shocking it?
    Jan 2014
    Buckeye AZ
    807
    "shocking" traditionally is "dump a bunch of stuff in one time and see what happens.
    Here, to kill the algae, you will raise the FC to shock levels and then keep it there as long as needed. That shock level can't be determined until you get a good set of test results.
    The bleach for now is just to keep the algae from getting much worse in the mean time.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Jun 2016
    Newburgh NY
    12
    Thank you!!
