Results 1 to 13 of 13
Thread: Cloudy water-scale inside of pool walls
    Jun 2013
    Seguin TX
    192
    Greetings,
    I have been slamming my pool a couple of weeks now, pump running 24x7, but I dont understand why the water does not want to clear up.
    Here are my readings.
    FC was 6.5 at 4pm yesterday, and tested at 5 at 10am this morning with no added bleach.
    PH=7.8
    TA=130
    CH=80
    CYA=40
    I have stopped the pump for now hoping the "sediment" in the water "looks like white snow flakes" will settle out to the bottom where I can vacuum it up.
    My filter sand is old "from another filter" but was cleaned before it was put into service last year, I have not deep cleaned it this year.
    I go 2-3 days between backwash, and the initial flow is pale milky color.
    Ideas? Thanks in advance.
    2017-Intex Ultra Frame 16x48 5000 Gallons
    Intex 2800GPH Pump with 14" Intex Sand Filter
    My Intex Pool Setup Video :Intex pool rises from the ashes - installing and leveling - EP-72 - YouTube
    Jun 2014
    15,253
    Re: Cloudy water-scale inside of pool walls
    Hey neighbor. It looks like your FC is too low for your SLAM to work. For a CYA of 40, your FC should be at 16 (see Chlorine/CYA Chart link below). BEFORE you do that though, lower your pH to 7.2! That's very important. Lower your pH now, then hit HEB or Wal-Mart for some Bravo or Great Value bleach and keep the FC at 16.
    May 2011
    Abilene, KS
    67
    I'd recommend that you read Pool School again. Pay attention to the SLAM process
    and you'll be fine. The key is doing the homework and following the recommendations.
    25,000 gallon Vinyl Lined Inground. One skimmer, 2 returns. Pentair WhisperFlo WFDS-4, Hayward Pro Grid DE 3620 with VariFlow valve, LaarsLite 2 propane heater
    Jun 2013
    Seguin TX
    192
    Ok, so I bumped the FC to 16 per the slam instructions last night after the sun went down.
    This morning, I could almost see the bottom of the pool, tested and the FC had dropped to 12.5, added another 27oz of bleach to bring it back to 16.
    CC=0, now I can see some stuff on the bottom of the pool and the sides, so I am going out to brush the pool again, take another FC sample and dose back to 16 if needed.
    Sound right?
    P.S. Added a skimmer sock to help with some of the fine particles the sand filter would otherwise miss.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Quote Originally Posted by unkyjoe View Post
    Sound right?
    You got it!
    If any of your friends or neighbors have a DE filter, see if you can beg a couple cups of DE or cellulose to add. That will really strain out the fine stuff. Just make sure you're home to watch the gauge because it will load up fast.
    Jun 2013
    Seguin TX
    192
    Update:
    FC dropped to 12.5, dosed with 27oz bleach to bring back to 16, scrubbed the walls and floors again. Ladder is out of pool. I can nearly see the bottom. Will check FC again in 2 hrs and see if I need to dose again.
    I think I am slowly winning this war, keeping the FC at 16 is the key I was missing. I can see the difference.
    Jun 2013
    Seguin TX
    192
    The current state of the water. Getting closer
    Jun 2013
    Seguin TX
    192
    P.S. My PH jumped from 7.2 to 7.6 because my return fitting became exposed and was putting a lot of air into the water. I corrected the water level and the PH is now down to 7.4 and dropping. I have never had to add acid to my pool to lower it in the past.
    Jun 2013
    Seguin TX
    192
    Update:
    FC-16 after adding 37oz bleach atsundown last night.
    FC 14.5 at sunrise this morning.
    Can see the bottom of the pool again, however not as clear as I like so I will continue to SLAM until OCLT is 1 or less and water is crystal clear.
    Sound Right?
    Richard320's Avatar
    Jan 2010
    19,067
    Update:
    Sound Right?
    Yep.
    And here's the kicker: what you'll consider 'clear' now will become 'murky' in a few weeks' time. Regular brushing and balanced water just gets a certain clarity and sparkle you have to experience.
    Jun 2013
    Seguin TX
    192
    Water this AM was clear, FC was 4.5 this morning after adding bleach yesterday morning.
    One more day of SLAM today, then will do the OCLT test tonight to see if it holds, CC=0
    Jun 2013
    Seguin TX
    192
    Passed OCLT and water is crystal clear, however some sand in the pool I need to pickup now that I can see the bottom.
    Thanks for all of the help.
    Jun 2014
    15,253
    Nice work!
