Thread: Water clarifier
    Mar 2016
    Phoenix, AZ
    48
    Water clarifier
    I love using the TFP method. I slammed my pool a month ago and I now have 0.5 OCLT on average with 0 CCs.
    I maintain a CYA level of about 70 and my chlorine level is around 10-12. I do the DPD-FAS test twice a day and have just had to order new reagents due to using them so much.
    I have a sand filter that I use and backflush around once a week.
    My backyard in on the desert in Phoenix (South Mountain). My water was looking a little hazy, although I had no trouble seeing the bottom of the deep end of the pool. My numbers were all good. I decided to add a little "water clarifier" to the pool. It cleared up the pool overnight. When I backflushed the filter a bunch of darker water came out initially from the backflush port. I think that dust from the desert enters the pool and it's too fine for the sand filter to capture.
    Is there any problem with adding a bit of clarifier now and then to "brighten" up the pool?
    10,000 gallon, inground, pebblesheen, sand filter, TF-100 testing kit, Pentair Rebel
    Mar 2016
    Easley, SC
    380
    Re: Water clarifier
    I would use a skimmer sock and add some DE to help filter it out better. I have the same issue but mine is with pollen. The water looks completely clear with a slight haze. Once I added the sock I could actually see what the sand filer was not catching. It actually cleared it up very well but once I added the DE I was totally amazed at how clear the water can be!
    18x36 inground / 28k gal / Phanton vinyl liner (replaced in 2009) / Hayward Pro Series sand filter / Hayward 1hp pool pump / Hayward 3/4hp booster pump
    Mar 2016
    Phoenix, AZ
    48
    Re: Water clarifier
    That's what I was thinking. I used to have a DE filter. How much DE do you add between backflushes?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Water clarifier
    Quote Originally Posted by skydude View Post
    Add slowly and watch your pressure gauge. Stop adding wen the pressure rises 1psi
    Support the site
    Mar 2016
    Easley, SC
    380
    Re: Water clarifier
    I use about 1 cup to get my psi up 1lb. I used this for guidance.
    Pool School - Add DE to a Sand Filter
    Mar 2016
    Phoenix, AZ
    48
    Re: Water clarifier
    Thanks for all the information!
