Thread: chlorine test
    May 2016
    Arlington TX (DFW)
    7
    chlorine test
    When using the k-2006 chlorine test kit, is there any reason to use the 25ML vs the 10ML? I have been using the 25 but figured I could save some reagent by using the 10ML measurement.
    Thanks!!!
    18 x 36 24,000 in ground liner pool. built 1978, New liner in 2016. DE filter, DFW Texas, Taylor k-2006
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: chlorine test
    You can go ahead and use 10 mL sample for 0.5 ppm accuracy. It will save you reagents and is close enough for us.
    Support the site
    Jul 2015
    Central Valley CA
    1,109
    Re: chlorine test
    Most just use the 10ml no reason to be that precise .5 even 1 PPM resolution is good enough.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    May 2016
    Arlington TX (DFW)
    7
    Re: chlorine test
    Thanks!!!
