Thread: PoolMath question
    Aug 2015
    Petersburgh, NY
    79
    PoolMath question
    When I put my pool size and all of my current numbers into the PoolMath tool, it gives me a normal range for the suggested FC levels. In my case it says the normal range for FC level is 2 to 6. Is this the range I should try to maintain FC levels, so that the pool is safe for swimming? If not, what is the recommended FC level to maintain?
    Thanks
    Chuck
    - Chuck - My pool: Fiberglass (Aug 2014); 19,324 gallons, 1.5-hp pump; Hayward Sand Filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: PoolMath question
    FC/CYA Chart
    Quote Originally Posted by cedougl View Post
    Thanks
    Chuck
