Results 1 to 9 of 9
Thread: Vinyl in pool feels like sandpaper
    Jun 2016
    Warren Michigan
    3
    Hi everyone...im new at this site. Im having scaling problems with my AG intex pool vinyl18x48 intex sand filter pump 3000gph. I went to pool store to get my water tested. They said everything was normal besides my stabalizer. I put 2lb like the lady said in nylon tired it to the ladder 2 days later my pool is still cloudy and sides still feel like sandpaper. The pool placed was shocked that my vinyl felt like sandpaper when my hardness was fine. I also been scrubbing the sides with the scrub brush no luck...
    Im so overwhelmed...feel like giving up..
    FC 0.17
    TC 0.56
    CC 0.39
    PH 7.8
    Hardness 215
    Alkalinity 108
    CA 1
    Copper 0
    Iron 0
    Phosphate 159.86ppb
    My test from pool store.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Vinyl in pool feels like sandpaper
    Welcome to TFP!
    Your problem is likely your pH being so high. If you'll carefully lower it with muriatic acid you may find the calcium goes back into the water.
    Does your water supply have that same calcium level, or have you been using powdered shock with calcium? If your water supply is lower hardness, you may be best to just empty and refill the pool and avoid calcium products in the future.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP!
    Lower your PH to 7.2 to 7.4 and brush the pool daily. That should take care of the scale.
    Your chlorine is too low. Keep it at 4 ppm.
    How are you chlorinating the pool?
    Keep squeezing that knee high to help dissolve the CYA.
    Jun 2016
    Warren Michigan
    3
    My ph is down to 7.2 chlorine is at 3ppm
    Still nothing...i use hth powder chlorine. i did empty the pool and refilled it this summer..im using hth super shock treatment i dont know if it has calcium in it. Im using the same chemicals i used last summer. Did not have this problem last year Water supply said my calcium level was 215 which she said was good that she dont know why my sides feel like sandpaper. Also its so cloudy and sometimes it looks like there is soap floating on top of the water and in the skimmer there will be foam. should i shock it again?
    May 2015
    Mount Cheaha Alabama
    250
    I can't zoom in over the product to see it well enough, but if you could confirm the "active ingredients" are calcium hypochlorite and something else?
    the calcium attached to the hypo(chlorine) is what is making your water cloudy.
    Don't shock again. Pick up some bleach 10%(6 gallons) for chlorinating pools and some "stabilizer" CYA, cynuaric acid to protect your chlorine.
    30k in ground vinyl lined pool surrounded by decking in the woods.
    Hayward sand filter circa mid 80's
    If there is a way to do things less expensively and yield a superior product I am all ears
    DFW, TX
    24,485
    It will probably take several weeks of brushing to remove the scale.
    CH at 215 is fine.
    There are 3 kinds of powdered shock
    Dichlor, contains chlorine and CYA
    Trichlor, contains chlorine and CYA
    Cal-hypo, Contains chlorine and calcium (CH)
    If you are using cal-hypo that could cause the cloudiness, if it is it will clear up in a couple of days.
    Jun 2016
    Warren Michigan
    3
    In my powder shock in the active ingredient there is calcium hypo 56.44%
    So this is my problem?
    What is a good brand of shock to use?
    And chlorine?
    Now what do i do now? Get the bleach 10% 6 gallons put that in. i put CYA 4days ago.
    Could my powder chlorine have the calcium hypo?
    Thank you everyone for ur help.
    DFW, TX
    24,485
    We do prefer to use liquid chlorine or bleach to chlorinate the pool because they don't add other chemicals. More here Pool School - How to Chlorinate Your Pool
    May 2015
    250
    Quote Originally Posted by Kati1223 View Post
    And chlorine?
    Don't add all the bleach at once.
    I recommend getting some for a few weeks of treatment, you'll probably need ~1/2gal a day until the CYA on your pool is in range 30-40.
    If you're serious about getting the pool under control, buy the test kit offered from this site.
