Results 1 to 7 of 7
Thread: Please Manual Clean Your DE Grids.
    Jul 2013
    Central New Jersey
    55
    I'll admit I haven't taken my DE filter apart for about 3 years now, mind you I only backwash and recharge the thing once maybe twice per season. I have a mesh safety cover and more laziness stopped me from adding chlorine during the winter, so I started with basically a swamp this years. The filter just wasn't working as fast as in years past, so I broke the thing apart and man I wish I had taken some pictures. It is insane how much DE is left behind even after a vigorous back-washing session. There were just huge clumps of DE some almost top to bottom in between all the inside grids, so please take the word of a lazy guy, get off your butt and manual clean your filter at least once per season.
    26K Gallon, IG vinyl
    1.5 HP Hayward Super Pump, DE Filter 36 SqFt
    Older than time TELEDYNE LAARS HEATER (removed from system for now)
    38,539
    Re: Please Manual Clean Your DE Grids.
    I totally agree. Even after just one backwash cycle there seems to be a lot of DE left over.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I've pretty much switched to breakdown cleaning mine every time. I was doing it once a season, then started doing it spring and fall. I noticed that it was still pretty bad. Since I start a breakdown by backwashing first, it shows how much you don't get out by just backwashing. I notice that the pressure drops more after a full cleaning and that it stays down longer. I guess it really isn't that much more work than those who have a cartridge filter. Same process, just more mess with the DE.
    chiefwej
    Jul 2013
    Central New Jersey
    55
    Quote Originally Posted by chiefwej View Post
    Yea I'm thinking of doing the same thing from now on. Plus no matter where I back wash I get some DE sitting in low spots on the lawn. The last thing I want to do is run over all that DE with the lawn mower kicking it all up in the air and breathing it in. When I take the grids out I can wash them in the street and the DE all runs down the storm drain. I also try and schedule my cleanings before heavy rain fall so that any DE that is left over, be it in the street or lawn is washed away.
    Jan 2014
    Buckeye AZ
    807
    I scrape what I can down into the bottom section of the filter before pulling the grids out. Then I scoop all that out and let it dry some before double trash bagging it.
    I still see sections of uncovered grid though. Haven't nailed the coverage yet. Guess I could slowly add DE until the pressure starts moving up.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Jul 2013
    Central New Jersey
    55
    Quote Originally Posted by BuckeyeChris View Post
    How are you adding the DE are you making a slurry by mixing it with water first or adding the powder straight to the skimmer? I'm kind of mixed on which works best in my setup as I have tried both. Though I would not recommend dumping the dry DE right in if you don't have at least 2 skimmers. I actually keep both my skimmers open during slurry or dry loading as I personally feel it promotes better mixture of the DE and hopefully better grid coverage.
    Jan 2014
    Buckeye AZ
    807
    I have tried both as well. Slurry last year, shake through skimmer this year. Can't really tell how well it worked until next year's disassembly, that's the downside.
    When I did the slurry last year, after a partial refill, I shut off the main drain and started before the water level was high enough, so I ran the skimmer dry. And forgot to shut off the venturi return. Had to stop, adjust, wait, etc, so it wasn't a very good job by me of adding the slurry, so I won't knock that method until I can do it cleanly.
