Thread: Pressure when using automated cleaner
    Sep 2015
    Rome, NY
    363
    My gauge usually reads 15 to 17 psi when using skimmer. When I use my Hayward bug automatic cleaner, it runs consistently at nine psi. Any issues? Anything I need to look at or change? Thank you
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pressure when using automated cleaner
    There is more restriction on the suction side when you have the cleaner on there. This means the pump is not able to pull as much volume of water at the same time as it does without the restriction. I would think this is fairly normal. Do you have just the one skimmer?
    Isolated Spa - 345 Gallons
    Sep 2015
    Rome, NY
    363
    Yes one skimmer.
