Thread: Need 15 (FC) but kit only goes to 10- Am I doing something wrong?
    May 2016
    us
    8
    Iím converting from Baquacil and the instructions stateto set target FC goal of 15 and test frequently bumping that number back up to15.
    However, I have the Taylor K-2005 kit and it only goes to10??? Iím confused because how can I know if itís at 15ppm?
    Here are the directions to convert from Baquacil where itstates 15 FC Pool School - Convert Your Baqua Pool to Chlorine
    The instructions state:
    1. Rinse and fill small comparator tube to 9 mLmark with water to be tested
    2. Add 5 drops R-0001 and 5 drops R00002. Cap andinvert to mix
    3. Match color with color standard. Record as partsper million (ppm) free chlorine (FC)
    Here is the tester I have
    domct203's Avatar
    Jun 2015
    CT
    3,577
    Re: Need 15 (FC) but kit only goes to 10- Am I doing something wrong?
    The K-2005 is a DPD Chlorine test and as you have discovered only goes to 10 ppm.
    You need a FAS-DPD Chlorine test like this one at TFTestkits.net
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2016
    us
    8
    Ahhh. that's not good. Do local pool stores usually carry FAS-DPD ones? I called Leslies and they said no
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    331
    Not usually. You can get one here TFTestkits.net .
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    38,248
    You might be able to find one locally at a commercial pool store
