Thread: PH and TA , what to do?
    Apr 2013
    South California
    69
    PH = 8.2
    TA = 50
    If I add MA to bring down PH, TA level will be down to. If I add baking soda to bring TA up, PH will be up to.
    What should I do?
    Summer Escape 4k gal-AG
    Intex sand filter 1600 GPH
    Intex SWG model 54601
    Taylor K2006 kit & Taylor Salt Water Test Kit K-1766
    Installed 4/29/13
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: PH and TA , what to do?
    Punt! Always maintain your PH between 7.2 and 7.8 no matter what. Baking soda will raise your TA and not your PH. Raise your TA to 60 and see how it goes.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I would also suggest raising your TA to 60 first, then dropping the pH, but only to about 7.6. If you're fighting pH rise even at TA of 50 or 60, never lower your pH below 7.6 if you can help it. Low TA helps prevent pH rise but pH rise is also slower at higher pH levels. So if you're never very low, such as 7.0-7.4, you'll experience less overall pH rise and have to worry about TA being too low as often.
    Isolated Spa - 345 Gallons
