Thread: I think floor drain is blocked-skimmer drain works
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    Hello again,
    My pool floor drain has what looks like a shower head with 3 triangles in it(picture the radiation symbol), I will take a picture of it when it stops raining.
    I have 1 skimmer & 1 floor drain & I think the floor drain is plugged or turned off at the drain, only 1 line comes out of the ground to the pump.
    When I cover the skimmer drain with my hand the pump looses all water, so I think the floor drain is plugged, BUT I am able to turn the drain cover around with the net handle.
    At one time did they make on/off floor drains?
    I am thinking of turning off the return line valve at the pump & sticking one of those clog busters into the skimmer drain & trying to clear the floor drain that way
    Is that a good idea?
    TIA
    Bob
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
    30,403
    Re: I think floor drain is blocked-skimmer drain works
    Bob,
    The main drain may be plumbed into the skimmer. Do you have one or two holes in the bottom of the skimmer?
    Bob_Funk's Avatar
    May 2009
    113
    duraleigh,
    you are DA MAN!!!!!!!!!!!!!!!!!!!!!!!!
    My skimmer had a bunch of sand in it from blind vacuuming when the pool was green, so after your post I shut off the pump & took a good look & sure enough there is a small valve in there, had the wife come out & watch what happened at the pump when i turned the lever(I had the valve on recirculate) & BAM pine needles & sand shot out of the return & a bunch of gravel & assorted **** filled the pump basket.
    Flow to the skimmer went down dramaticly yet I still had full volume of water to the pump.
    My pool will be totally clear tomorrow morning!
    I can not thank you enough, if I had paid a pool company $200+ to turn that valve for me---%$#& *^%$#@
    If it wasn't for this forum I would be complaining about how tired I am from filling in the pool in.
    Thanks again
    Bob
